- Select SPBM.
- Select the Multicast FIB tab.
Multicast FIB Field Descriptions
Use the data in the following table to use the Multicast FIB tab.
| Name | Description |
| SysId | System ID of the node where the multicast FIB entry originated. |
| Vlan | VLAN of the multicast FIB entry. |
| McastDestMacAddr | Multicast destination MAC Address of the multicast FIB entry |
| Isid | I-SID of the multicast FIB entry. |
| Isid Name | Name assigned to the I-SID. |
| HostName | Host name of the node where the multicast FIB entry originated. |
| OutgoingInterfaces | Specifies the switched UNI port outgoing interface of multicast FIB entry. |
| IncomingInterface | Specifies the incoming interface (port or MLT) of the multicast FIB entry. |
